Ir para o conteúdo principal
Nerf Dart Tag Furyfire Pump Track Replacement
O que você precisa
  1. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the screws: passo 1, imagem 1 %32
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Panel: passo 2, imagem 1 %32
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Black Cylinder: passo 3, imagem 1 %32
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: passo 4, imagem 1 %32 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: passo 4, imagem 2 %32
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Pump Handle: passo 5, imagem 1 %32
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Handle: passo 6, imagem 1 %32
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: passo 7, imagem 1 %32 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: passo 7, imagem 2 %32
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Pump Track Replacement, Disengage White Piece: passo 8, imagem 1 %32
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: passo 9, imagem 1 %32 Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: passo 9, imagem 2 %32
    • Using your hand, slide the track out of the gun by pulling it away form the device.
Conclusão
Uma outra pessoa concluiu este guia.
Bradley Penrow
Membro desde: 09/23/14
37 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 11-2, Blackwell Fall 2014 Membro de USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 484
