Ir para o conteúdo principal
Nerf Dart Tag Furyfire Large Spring Replacement
O que você precisa
  1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove the screws: passo 1, imagem 1 %32
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Panel: passo 2, imagem 1 %32
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Black Cylinder: passo 3, imagem 1 %32
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: passo 4, imagem 1 %32 Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: passo 4, imagem 2 %32
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
Conclusão
Bradley Penrow
Membro desde: 09/23/14
37 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 11-2, Blackwell Fall 2014 Membro de USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 1,515
