Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Flip the Neato on its back so the bottom is exposed
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Lift the panels to reveal the batteries, brush and fan
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. The Neato's core components are now exposed and ready to be cleaned and/or replaced.
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Pinch and pull the white connector to disconnect the battery from the device
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Apple Watch Kits
    Screen and battery repairs just got easier.
    Comprar agora
    Apple Watch Kits
    Comprar agora
  6. Remove the 17 visible screws and the 2 covered/hidden screws near the battery compartments that connect the bottom to the top of the Neato robot.
    • Remove the 17 visible screws and the 2 covered/hidden screws near the battery compartments that connect the bottom to the top of the Neato robot.
  7. Lift and separate the two pieces to  give access to the Distance Sensor
    • Lift and separate the two pieces to give access to the Distance Sensor
    • There may be slight resistance during this step, make sure to lift the pieces straight rather than an angle. Lifting at an angle may cause pieces to catch, causing resistance
  8. Remove the four screws on the lidar sensor. After the wires are fully disconnected lift the motor away to reveal the motherboard There should be little to no resistance during this step. Do not continue if there is resistance, this may damage the motherboard
    • Remove the four screws on the lidar sensor.
    • After the wires are fully disconnected lift the motor away to reveal the motherboard
    • There should be little to no resistance during this step. Do not continue if there is resistance, this may damage the motherboard
  9. Pinch and pull the white connectors indicated in the image, this will allow the top and bottom panels to fully seperate
    • Pinch and pull the white connectors indicated in the image, this will allow the top and bottom panels to fully seperate
  10. Pinch and pull the white connectors that connect the LCD screen and motherboard components
    • Pinch and pull the white connectors that connect the LCD screen and motherboard components
  11. Remove the four screws that hold down the motherboard.
    • Remove the four screws that hold down the motherboard.
  12. Lift motherboard off of the device so that the new motherboard can be connected
    • Lift motherboard off of the device so that the new motherboard can be connected
    • There should be little to no resistance during this step. Do not continue if there is resistance, this could cause damage to the motherboard
Conclusão
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 60
Todo: 996
