Ir para o conteúdo principal
Neato XV-21 Fan Replacement
O que você precisa
  1. Neato XV-21 Fan Replacement, Back Panels of Neato XV-21: passo 1, imagem 1 %32
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Fan Replacement: passo 2, imagem 1 %32
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Fan Replacement: passo 3, imagem 1 %32
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Fan Replacement, Battery: passo 4, imagem 1 %32
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Fan Replacement, Fan: passo 5, imagem 1 %32 Neato XV-21 Fan Replacement, Fan: passo 5, imagem 2 %32
    • Pinch the white connectors to disconnect the fan from the robot, as previously done with the batteries
    • Once the wires are disconnected lift the fan from the cavity
  6. Neato XV-21 Fan Replacement: passo 6, imagem 1 %32
    • Once the fan has been removed you can take a damp cloth and clean the cavity before attaching the new device
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 1,134
