Ir para o conteúdo principal
Neato XV-21 Battery Replacement/Removal
O que você precisa
  1. Neato XV-21 Battery Replacement/Removal, Back Panels of Neato XV-21: passo 1, imagem 1 %32
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Battery Replacement/Removal: passo 2, imagem 1 %32
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Battery Replacement/Removal: passo 3, imagem 1 %32
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Battery Replacement/Removal, Battery: passo 4, imagem 1 %32
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
Can someone tell me the specs of screws for the back panels? unfortunately I lost the 8 screws!!!
mflorest - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 38
Duração total: 1,219
