Ir para o conteúdo principal
Neato Botvac D75 LCD Screen Replacement
O que você precisa
  1. Neato Botvac D75 LCD Screen Replacement, Battery: passo 1, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement, Battery: passo 1, imagem 2 %32 Neato Botvac D75 LCD Screen Replacement, Battery: passo 1, imagem 3 %32
    • Use Phillips #1 screwdriver to unscrew the two bottom cover screws
    • Be careful, the screws are self-retained on the cover itself and does not come off the battery cover.
  2. Neato Botvac D75 LCD Screen Replacement: passo 2, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement: passo 2, imagem 2 %32 Neato Botvac D75 LCD Screen Replacement: passo 2, imagem 3 %32
    • Lift battery cover out.
  3. Neato Botvac D75 LCD Screen Replacement: passo 3, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement: passo 3, imagem 2 %32 Neato Botvac D75 LCD Screen Replacement: passo 3, imagem 3 %32
    • Be careful when taking out the battery. Do not pull on the wires or battery trying to get the connector out.
    • The cord has prongs on it that are a little difficult to get out. Use a flathead screwdriver to press the release tab on the connector to remove it.
  4. Neato Botvac D75 LCD Screen Replacement, Brushes: passo 4, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement, Brushes: passo 4, imagem 2 %32 Neato Botvac D75 LCD Screen Replacement, Brushes: passo 4, imagem 3 %32
    • To remove the rotary brush simply grasp it firmly and pull it off.
  5. Neato Botvac D75 LCD Screen Replacement: passo 5, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement: passo 5, imagem 2 %32 Neato Botvac D75 LCD Screen Replacement: passo 5, imagem 3 %32
    • Once you have everything out get the plastic opening tool and pry open the large black plastic piece.
    • With a little force it should come out.
    • The boxes show you were the clips are that hold this piece
  6. Neato Botvac D75 LCD Screen Replacement: passo 6, imagem 1 %32
    • Once the black piece has been taken out, the brush just comes out easily.
  7. Neato Botvac D75 LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement, LCD Screen: passo 7, imagem 2 %32
    • Firmly grasp the back cover and pull away from the Botvac one side at a time.
    • Removing the cover will expose two 1.3mm T10 screws that must be removed to separate the cover halves.
  8. Neato Botvac D75 LCD Screen Replacement: passo 8, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement: passo 8, imagem 2 %32
    • Remove these two 13mm T10 screws. You will need to use the extension in your tool set since they are deep in the casting.
  9. Neato Botvac D75 LCD Screen Replacement: passo 9, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement: passo 9, imagem 2 %32
    • Eight 13mm T10 screws on the underside of the Botvac hold the casing together. These screws are not self-retained so make sure that you don’t lose them in the disassembly process.
  10. Neato Botvac D75 LCD Screen Replacement: passo 10, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement: passo 10, imagem 2 %32 Neato Botvac D75 LCD Screen Replacement: passo 10, imagem 3 %32
    • The screws pictured here on either side of the Botvac require the extension in your tool set to be removed.
  11. Neato Botvac D75 LCD Screen Replacement: passo 11, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement: passo 11, imagem 2 %32
    • On the back of the Botvac there are two retaining tabs that must be pressed to be released.
    • With the tabs released the top and bottom cover halves can be separated.
  12. Neato Botvac D75 LCD Screen Replacement: passo 12, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement: passo 12, imagem 2 %32 Neato Botvac D75 LCD Screen Replacement: passo 12, imagem 3 %32
    • Carefully lift the top cover of the Botvac. On the right side of the Botvac is where you'll find the LCD screen connector to the motherboard. Carefully pull on the connector to disconnect it from the motherboard.
  13. Neato Botvac D75 LCD Screen Replacement: passo 13, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement: passo 13, imagem 2 %32 Neato Botvac D75 LCD Screen Replacement: passo 13, imagem 3 %32
    • There are two 0.5cm #1 Phillips screws holding the LCD screen to the top cover. Remove these screws to lift screen off the cover.
  14. Neato Botvac D75 LCD Screen Replacement: passo 14, imagem 1 %32 Neato Botvac D75 LCD Screen Replacement: passo 14, imagem 2 %32 Neato Botvac D75 LCD Screen Replacement: passo 14, imagem 3 %32
    • With the two screws removed you may lift the screen off the cover. Carefully remove the connector from the screen by pulling on the connector.
Conclusão
Juan Cornejo
Membro desde: 02/15/17
597 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S6-G5, Lacy Spring 2017 Membro de USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 2,955
