Ir para o conteúdo principal
Neato Botvac D75 Brushes Replacement
O que você precisa
  1. Neato Botvac D75 Brushes Replacement, Brushes: passo 1, imagem 1 %32 Neato Botvac D75 Brushes Replacement, Brushes: passo 1, imagem 2 %32 Neato Botvac D75 Brushes Replacement, Brushes: passo 1, imagem 3 %32
    • To remove the rotary brush simply grasp it firmly and pull it off.
  2. Neato Botvac D75 Brushes Replacement: passo 2, imagem 1 %32 Neato Botvac D75 Brushes Replacement: passo 2, imagem 2 %32 Neato Botvac D75 Brushes Replacement: passo 2, imagem 3 %32
    • Once you have everything out get the plastic opening tool and pry open the large black plastic piece.
    • With a little force it should come out.
    • The boxes show you were the clips are that hold this piece
  3. Neato Botvac D75 Brushes Replacement: passo 3, imagem 1 %32
    • Once the black piece has been taken out, the brush just comes out easily.
Conclusão
Juan Cornejo
Membro desde: 02/15/17
597 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S6-G5, Lacy Spring 2017 Membro de USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
4 Membros
Autoria de 10 guias
1Comentário do guia
I have removed and cleaned the brush but it still won't run due to the error message to clean the brush. The machine has only run 5 or 6 times so brand new machine.
keytkey - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 9
Ao todo: 949
