Ir para o conteúdo principal
Neato Botvac Connected Screen Replacement
O que você precisa
  1. Neato Botvac Connected Screen Replacement, Screen: passo 1, imagem 1 %32 Neato Botvac Connected Screen Replacement, Screen: passo 1, imagem 2 %32 Neato Botvac Connected Screen Replacement, Screen: passo 1, imagem 3 %32
    • Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
    • Remove the four screws lining the front roller using a TR10 Torx screwdriver.
    • Remove the black panel behind and in front of the roller.
    • Gently lift the roller by the right side to remove it.
  2. Neato Botvac Connected Screen Replacement: passo 2, imagem 1 %32
    • Remove the two screws behind the front roller of the robot using a Phillips #2 screwdriver.
    • Remove the battery by lifting it out while pressing down on the wire clip inside the compartment.
  3. Neato Botvac Connected Screen Replacement: passo 3, imagem 1 %32 Neato Botvac Connected Screen Replacement: passo 3, imagem 2 %32 Neato Botvac Connected Screen Replacement: passo 3, imagem 3 %32
    • Pull one side of the front bumper out and then forward toward you. Repeat on the other side to completely detach the front bumper.
  4. Neato Botvac Connected Screen Replacement: passo 4, imagem 1 %32 Neato Botvac Connected Screen Replacement: passo 4, imagem 2 %32
    • Remove the eight screws from the underside of the Botvac using a TR10 Torx screwdriver.
    • Remove the additional two TR10 screws from the top of the Botvac.
    • Remove the dustbin.
  5. Neato Botvac Connected Screen Replacement: passo 5, imagem 1 %32 Neato Botvac Connected Screen Replacement: passo 5, imagem 2 %32 Neato Botvac Connected Screen Replacement: passo 5, imagem 3 %32
    • Pry the clips on the front of the robot apart.
    • Unplug the beige connector with a spudger, working one side at a time until it comes unplugged.
    • Make certain not to not to tear any wires out of the port.
    • Lay the top of the robot inside up.
  6. Neato Botvac Connected Screen Replacement: passo 6, imagem 1 %32 Neato Botvac Connected Screen Replacement: passo 6, imagem 2 %32
    • Unplug the beige connector with a spudger. Be careful not to tear out any wires.
    • Remove the two screws from the screen using a TR10 Torx screwdriver.
    • Remove the screen from the vacuum.
Conclusão
Jerome
Membro desde: 03/01/23
365 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 148
