Ir para o conteúdo principal
Neato Botvac 65 Top Cover Removal
O que você precisa
  1. Neato Botvac 65 Top Cover Removal, Battery: passo 1, imagem 1 %32 Neato Botvac 65 Top Cover Removal, Battery: passo 1, imagem 2 %32
    • Flip the device upside down.
    • Locate the two (2) 20mm screws on the batttery plate.
  2. Neato Botvac 65 Top Cover Removal: passo 2, imagem 1 %32 Neato Botvac 65 Top Cover Removal: passo 2, imagem 2 %32
    • Use the Phillips #1 screwdriver to loosen both screws.
  3. Neato Botvac 65 Top Cover Removal: passo 3, imagem 1 %32
    • Remove the battery back plate to reveal the battery.
  4. Neato Botvac 65 Top Cover Removal: passo 4, imagem 1 %32 Neato Botvac 65 Top Cover Removal: passo 4, imagem 2 %32
    • Disconnect the current battery by pulling the connector from the base and pushing on the clip.
  5. Neato Botvac 65 Top Cover Removal, Brush: passo 5, imagem 1 %32
  6. Neato Botvac 65 Top Cover Removal: passo 6, imagem 1 %32 Neato Botvac 65 Top Cover Removal: passo 6, imagem 2 %32
    • Use the screwdriver to take off the four (4) 10mm screws located near the brush which secure the plastic guard.
  7. Neato Botvac 65 Top Cover Removal: passo 7, imagem 1 %32 Neato Botvac 65 Top Cover Removal: passo 7, imagem 2 %32
    • Remove the plastic brush guard.
    • Pull off the plastic covering the brush.
  8. Neato Botvac 65 Top Cover Removal: passo 8, imagem 1 %32
    • Lift the brush to clean or replace.
  9. Neato Botvac 65 Top Cover Removal, Top Cover: passo 9, imagem 1 %32
    • Flip device upside down.
    • Locate the six (6) screw connected to the top cover.
  10. Neato Botvac 65 Top Cover Removal: passo 10, imagem 1 %32
    • Remove eight (8) star screws using the T10 bit.
  11. Neato Botvac 65 Top Cover Removal: passo 11, imagem 1 %32 Neato Botvac 65 Top Cover Removal: passo 11, imagem 2 %32
    • Pull off one side of the brush front cover, and then pull off the other.
  12. Neato Botvac 65 Top Cover Removal: passo 12, imagem 1 %32
    • Flip right side up and turn around.
    • FInd the two clips connecting the top cover to the body of the device.
  13. Neato Botvac 65 Top Cover Removal: passo 13, imagem 1 %32 Neato Botvac 65 Top Cover Removal: passo 13, imagem 2 %32
    • Lift up on the top cover gently.
    • Disconnect the connector from the motherboard to detach the top cover from the robot.
Conclusão
Joseph Caton
Membro desde: 02/15/17
334 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S2-G1, Lacy Spring 2017 Membro de USF Tampa, Team S2-G1, Lacy Spring 2017
USFT-LACY-S17S2G1
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 1,274
