Introdução
If your robot is struggling to scoot across the floor, the wheels may be jammed up. You will want to remove and clean, or even replace the wheels when necessary. As a prerequisite, make sure you remove the main roller brush before attempting to replace the brush motor.
O que você precisa
Turn the Neato Botvac upside down so the brushes and wheels are facing upward.
Pop the tabs shown on the main brush cover, and then pull. It should come right off. You can put it aside for now.
The bumper bar needs to come off next. There are two tabs that are holding it on either side of the brush housing.
Pull one side away from the brush bar. Keep in mind while this plastic is strong it is not invincible.
After dislodging the bumper bar from the main housing, pull it towards the front of the BOTVAC.
