Ir para o conteúdo principal
Neato BOTVAC CONNECTED Side Brush Replacement
O que você precisa
  1. Neato BOTVAC CONNECTED Side Brush Replacement, Battery: passo 1, imagem 1 %32
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Side Brush Replacement: passo 2, imagem 1 %32 Neato BOTVAC CONNECTED Side Brush Replacement: passo 2, imagem 2 %32
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Side Brush Replacement: passo 3, imagem 1 %32 Neato BOTVAC CONNECTED Side Brush Replacement: passo 3, imagem 2 %32
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Side Brush Replacement: passo 4, imagem 1 %32 Neato BOTVAC CONNECTED Side Brush Replacement: passo 4, imagem 2 %32 Neato BOTVAC CONNECTED Side Brush Replacement: passo 4, imagem 3 %32
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Side Brush Replacement: passo 5, imagem 1 %32
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Side Brush Replacement, Front Roller Brush: passo 6, imagem 1 %32 Neato BOTVAC CONNECTED Side Brush Replacement, Front Roller Brush: passo 6, imagem 2 %32
    • Remove the following screws with a Torx screwdriver:
    • Four 2.3 mm screws.
  7. Neato BOTVAC CONNECTED Side Brush Replacement: passo 7, imagem 1 %32
    • Gently remove the thin panel held by the four screws with a spudger.
  8. Neato BOTVAC CONNECTED Side Brush Replacement: passo 8, imagem 1 %32
    • Gently remove the two small wheels, and the axles attached to them.
  9. Neato BOTVAC CONNECTED Side Brush Replacement: passo 9, imagem 1 %32
    • Gently remove the panel that is on top of the front roller with the spudger.
  10. Neato BOTVAC CONNECTED Side Brush Replacement: passo 10, imagem 1 %32
    • Gently remove the front brush.
  11. Neato BOTVAC CONNECTED Side Brush Replacement, Side Brush: passo 11, imagem 1 %32 Neato BOTVAC CONNECTED Side Brush Replacement, Side Brush: passo 11, imagem 2 %32
    • Gently twist the side brush back and forth.
  12. Neato BOTVAC CONNECTED Side Brush Replacement: passo 12, imagem 1 %32 Neato BOTVAC CONNECTED Side Brush Replacement: passo 12, imagem 2 %32 Neato BOTVAC CONNECTED Side Brush Replacement: passo 12, imagem 3 %32
    • Spin the side brush counter counterclockwise.
  13. Neato BOTVAC CONNECTED Side Brush Replacement: passo 13, imagem 1 %32
    • Use the spudger to gently pry up and remove the side brush.
Conclusão
Justin Silva
Membro desde: 03/20/23
645 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 6-3, Botvin Spring 2023 Membro de UMass Dartmouth, Team 6-3, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 159
