Ir para o conteúdo principal
Navlinge LED lamp Pinching mechanism Replacement
O que você precisa
  1. Navlinge LED lamp Pinching mechanism Replacement, Crack appears: passo 1, imagem 1 %32
    • Crack appears due to a stress concentration which you cannot decrease due to a strong spring at the back.
  2. Navlinge LED lamp Pinching mechanism Replacement, Cut lower part of the pinch: passo 2, imagem 1 %32
    • At first you need to cut the lower (moving) jaw with a saw nd file it carefully.
    • Three wooden blocks would replace the mechanism (blue arrows). You will need to keep the original upper jaw (red arrow).
  3. Navlinge LED lamp Pinching mechanism Replacement, Use a pressure screw instead of  spring: passo 3, imagem 1 %32
    • On the lower wooden block, drill a hole and insert a fairly large screw. It should have flat end in order not to damage the support for the lamp (generally a bed or a shelf).
    • It would be difficult to do a thread in the wood (however, you can try). I inserted a nut into the wood to provide for the threaded support.
    • Inserting the nut is very tricky. As I have no special tools, I drilled a counter bore a little smaller than the nut. Then I hammered the nut into this bore.
    • The hammering is the trickiest part. If it is too light, the nut may move eventually, if it is too hard, the wood may break.
  4. Navlinge LED lamp Pinching mechanism Replacement, The size of the blocks: passo 4, imagem 1 %32
    • The empty space between the upper and lower block should be a little superior to the size of the shelf where your lamp is to be placed. In my case 40mm.
  5. Navlinge LED lamp Pinching mechanism Replacement, Lamp placed on the bed structure: passo 5, imagem 1 %32
    • The lamp has a new system of support.
    • Tighten the screw gently to hold it in place. Do not tighten a lot, the whole system may break.
Conclusão
It is a lot of work for a lamp which costs 10 euros, but I just cannot accept to buy a new one. The lamp may otherwise shine for many years.
Uma outra pessoa concluiu este guia.
Michal Ruzek
Membro desde: 01/27/22
463 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 30
Duração total: 312
