Ir para o conteúdo principal
Nabi Jr Speakers Replacement
O que você precisa
  1. Nabi Jr Speakers Replacement, Rear Case: passo 1, imagem 1 %32
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Speakers Replacement: passo 2, imagem 1 %32
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Speakers Replacement: passo 3, imagem 1 %32
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Speakers Replacement: passo 4, imagem 1 %32
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Speakers Replacement, Speakers: passo 5, imagem 1 %32
    • The speakers are located near the top of the device close to the camera.
    • Using a desoldering tool, remove the speakers from the pads they are soldered to.
    • Note that the red wire is removed from the pad labeled with a "+" and the black wire comes from the pad labeled with a "-".
    • Solder the new speaker's wires onto their respective pads
Conclusão
Tobias Young
Membro desde: 03/24/15
27 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 Membro de UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 849
