Ir para o conteúdo principal
Nabi Jr Battery Replacement
O que você precisa
  1. Nabi Jr Battery Replacement, Rear Case: passo 1, imagem 1 %32
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Battery Replacement: passo 2, imagem 1 %32
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Battery Replacement: passo 3, imagem 1 %32
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Battery Replacement: passo 4, imagem 1 %32
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Battery Replacement, Battery: passo 5, imagem 1 %32
    • Lift the battery up from the motherboard.
    • Don't rip the soldered wires from the board.
    • The battery is stuck to the motherboard with adhesive, it may take a little pull to separate.
  6. Nabi Jr Battery Replacement: passo 6, imagem 1 %32
    • Remove the battery from the motherboard
    • De-solder the colored wires
    • Be sure to note the order in which the wires are connected to the board before desoldering them.
    • Be careful while removing the solder off of the colored battery wires. The soldering iron will be extremely hot
  7. Nabi Jr Battery Replacement: passo 7, imagem 1 %32 Nabi Jr Battery Replacement: passo 7, imagem 2 %32
    • Replace the old battery with the new one
    • Solder the wires of the new battery into the pads on the motherboard
    • Be careful when soldering the wires in. Soldering iron will be extremely hot
  8. Nabi Jr Battery Replacement: passo 8, imagem 1 %32
    • Once the wires are fully soldered, put the new battery back to the initial position
    • Close the case by putting the back cover back on the device
    • Will take some force
    • Make sure the battery is not in the way of the back cover
  9. Nabi Jr Battery Replacement: passo 9, imagem 1 %32
    • Once the back cover is on, screw in the four screws that you had taken off in the beginning
    • Put the red rubber casing back on.
Conclusão
If all the steps were followed correctly, the device should be fully closed and ready to go
4 outras pessoas executaram este guia.
Jimmy Nguyen
Membro desde: 03/24/15
271 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 Membro de UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G3
Membros da 3
Autoria de 12 guias
7 comentários
Thank you for sharing the idea ,but I need that NABI JR battery. So ,where from I can purchase it .
Lus Ka - Responder
I have seen them on ebay but it's easier to find a Nabi 2 battery on ebay. The Nabi 2 battery is quite a bit larger but with a very minor mod to the Nabi Jr. the Nabi 2 battery will fit and give you a much longer run time from a single charge.
darcshadow -
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them.
Dennis Blixt - Responder
I have the same problem with the problem of the replacement battery not having the same wiring configuration or plug. Did you ever get this resolved?
Delores Duke -
Where can I buy the battery live in Mexico
Roos - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 11,741
