Ir para o conteúdo principal
NPET K10V3 Membrane Replacement
O que você precisa
  1. NPET K10V3 Membrane Replacement, Key Cap: passo 1, imagem 1 %32
    • Remove the keyboard from its power source.
  2. NPET K10V3 Membrane Replacement: passo 2, imagem 1 %32 NPET K10V3 Membrane Replacement: passo 2, imagem 2 %32
    • Firmly grasp the key that will be removed.
    • Remove the keycap by pulling directly upward.
    • Not pulling straight upward or securely will cause damage to the device.
    • If your fingers cannot get a good grip the key cap, use a key cap puller in the same orientation as with fingers.
  3. NPET K10V3 Membrane Replacement, Membrane: passo 3, imagem 1 %32
    • Flip the keyboard over so the bottom is facing upwards.
    • Remove fifteen 4.5 mm screws using a Phillips #2 screwdriver.
    • Remove three 9 mm screws using a Phillips #2 screwdriver.
    • Remove the screws from the kickstand plate first followed by the remaining screws for removal of the backplate.
  4. NPET K10V3 Membrane Replacement: passo 4, imagem 1 %32 NPET K10V3 Membrane Replacement: passo 4, imagem 2 %32
    • Remove the kickstand.
    • Remove the back plate.
    • Keep in mind the location of the USB cable to ensure it is not damaged when re-assembling.
  5. NPET K10V3 Membrane Replacement: passo 5, imagem 1 %32 NPET K10V3 Membrane Replacement: passo 5, imagem 2 %32
    • Remove the rubber gasket that compresses the connections.
    • When removing the gasket, lift straight upward to avoid damage and snagging.
    • Clean the gasket if there is any dirt or debris.
    • Do not use chemicals or liquids when cleaning to avoid damage.
  6. NPET K10V3 Membrane Replacement: passo 6, imagem 1 %32 NPET K10V3 Membrane Replacement: passo 6, imagem 2 %32
    • Remove the membrane gently to reveal the copper connections for both motherboard and membrane.
    • Remove the motherboard from the membrane.
    • Remove the membrane out with the motherboard.
    • When removing both parts, lift straight upward to avoid damage and snagging.
  7. NPET K10V3 Membrane Replacement: passo 7, imagem 1 %32
    • Place the membrane with the motherboard on a clean surface.
    • If the membrane is dirty around the key gaskets, clean gently without chemicals or liquids.
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Costa
Membro desde: 03/18/24
343 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-6, Konn Spring 2024 Membro de UMass Dartmouth, Team 2-6, Konn Spring 2024
UMASSD-KONN-S24S2G6
Membros da 5
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 89
