Introdução
This guide will show you how to replace the lens on the Nikon Coolpix A900.
You may need to replace the lens of the camera if it suffers a hard drop or water damage. A good indicator that you should replace the lens is if the lens has any kind of damage like a crack or scratches.
To help with this guide, make sure that you have a way to organize the components that you will be removing.
O que você precisa
Orient the camera so that it is upside down, with the lens facing towards you.
Orient the camera upside down, with the lens facing away from you.
Remove the two 3mm Phillips #00 screws from the right.
Remove the two 3.4mm Phillips #00 screws from the left.
Place the camera in front of you with the lens facing down.
On the top right, remove the 4.5 mm Phillips #00 screw holding the input shield.
6 outras pessoas executaram este guia.
2 comentários
How to replace the front-lens of the zoom-lens, when it’s scratched!?!
