Ir para o conteúdo principal
NABI XD Speakers Replacement
O que você precisa
  1. NABI XD Speakers Replacement, Rear panel: passo 1, imagem 1 %32 NABI XD Speakers Replacement, Rear panel: passo 1, imagem 2 %32
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Speakers Replacement: passo 2, imagem 1 %32
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Speakers Replacement, Battery: passo 3, imagem 1 %32 NABI XD Speakers Replacement, Battery: passo 3, imagem 2 %32
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Speakers Replacement: passo 4, imagem 1 %32
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. NABI XD Speakers Replacement, Charging port: passo 5, imagem 1 %32 NABI XD Speakers Replacement, Charging port: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  6. NABI XD Speakers Replacement: passo 6, imagem 1 %32
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
  7. NABI XD Speakers Replacement, Motherboard: passo 7, imagem 1 %32 NABI XD Speakers Replacement, Motherboard: passo 7, imagem 2 %32 NABI XD Speakers Replacement, Motherboard: passo 7, imagem 3 %32
    Comprar
    • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
    • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
    • You need to remove 4 ribbons
  8. NABI XD Speakers Replacement: passo 8, imagem 1 %32 NABI XD Speakers Replacement: passo 8, imagem 2 %32 NABI XD Speakers Replacement: passo 8, imagem 3 %32
    • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
    • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
  9. NABI XD Speakers Replacement: passo 9, imagem 1 %32 NABI XD Speakers Replacement: passo 9, imagem 2 %32
    • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
  10. NABI XD Speakers Replacement: passo 10, imagem 1 %32 NABI XD Speakers Replacement: passo 10, imagem 2 %32
    • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
  11. NABI XD Speakers Replacement: passo 11, imagem 1 %32
    • Lift the motherboard up away from the Nabi XD.
  12. NABI XD Speakers Replacement, Speakers: passo 12, imagem 1 %32 NABI XD Speakers Replacement, Speakers: passo 12, imagem 2 %32 NABI XD Speakers Replacement, Speakers: passo 12, imagem 3 %32
    • Right (R) speaker removal:
    • Remove one 4mm Phillips screw.
    • Use the metal spudger to separate the speaker from the frame.
    • The speaker is glued to the Nabi XD it will require some force to separate them.
  13. NABI XD Speakers Replacement: passo 13, imagem 1 %32 NABI XD Speakers Replacement: passo 13, imagem 2 %32
    • Remove the left (L) speaker wire from the frame by pulling it to the side and up.
    • The wire in this step, is connected to the charging port. Removing it, is shown in detail on step 6.
  14. NABI XD Speakers Replacement: passo 14, imagem 1 %32 NABI XD Speakers Replacement: passo 14, imagem 2 %32 NABI XD Speakers Replacement: passo 14, imagem 3 %32
    • Left (L) speaker removal:
    • Remove two 4mm Phillips screws.
Conclusão
Equipe
USF Tampa, Team 17-2, Blackwell Fall 2016 Membro de USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 159
