Ir para o conteúdo principal
NABI XD Motherboard Replacement
O que você precisa
  1. NABI XD Motherboard Replacement, Rear panel: passo 1, imagem 1 %32 NABI XD Motherboard Replacement, Rear panel: passo 1, imagem 2 %32
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Motherboard Replacement: passo 2, imagem 1 %32
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Motherboard Replacement, Battery: passo 3, imagem 1 %32 NABI XD Motherboard Replacement, Battery: passo 3, imagem 2 %32
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Motherboard Replacement: passo 4, imagem 1 %32
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. NABI XD Motherboard Replacement, Charging port: passo 5, imagem 1 %32 NABI XD Motherboard Replacement, Charging port: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  6. NABI XD Motherboard Replacement: passo 6, imagem 1 %32
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
  7. NABI XD Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 NABI XD Motherboard Replacement, Motherboard: passo 7, imagem 2 %32 NABI XD Motherboard Replacement, Motherboard: passo 7, imagem 3 %32
    Comprar
    • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
    • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
    • You need to remove 4 ribbons
  8. NABI XD Motherboard Replacement: passo 8, imagem 1 %32 NABI XD Motherboard Replacement: passo 8, imagem 2 %32 NABI XD Motherboard Replacement: passo 8, imagem 3 %32
    • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
    • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
  9. NABI XD Motherboard Replacement: passo 9, imagem 1 %32 NABI XD Motherboard Replacement: passo 9, imagem 2 %32
    • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
  10. NABI XD Motherboard Replacement: passo 10, imagem 1 %32 NABI XD Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
  11. NABI XD Motherboard Replacement: passo 11, imagem 1 %32
    • Lift the motherboard up away from the Nabi XD.
Conclusão
Equipe
USF Tampa, Team 17-2, Blackwell Fall 2016 Membro de USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
Membros da 3
Autoria de 12 guias
Um comentário
Donde puedo conprar la pelicula de la tables o el displey y tatil
maria-201309 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 252
