Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Is your charging port damaged, can't charge your device no matter what you have tried. Replacing the charging port may fix those problems.
Peças
Nenhum componente especificado.
  1. Use the plastic opening tool at the top left corner seam, then pry the corner apart. Use the plastic opening tool at the top left corner seam, then pry the corner apart.
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Place your fingernails on both sides of the connector and pull it straight back away from the holder. Place your fingernails on both sides of the connector and pull it straight back away from the holder.
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  5. Battery is glued to the base, lift carefully.
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  6. Remove the two 4mm Phillips screws with the PH#0 screwdriver. Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  7. Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
Conclusão
Marissa Schiereck
Membro desde: 15-09-2016
638 Reputação
6 Guias de autoria
equipe
USF Tampa, Team 17-2, Blackwell Fall 2016 Membro de USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Membros
12 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 407
