Ir para o conteúdo principal
NABI XD Battery Replacement
O que você precisa
  1. NABI XD Battery Replacement, Rear panel: passo 1, imagem 1 %32 NABI XD Battery Replacement, Rear panel: passo 1, imagem 2 %32
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Battery Replacement: passo 2, imagem 1 %32
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Battery Replacement, Battery: passo 3, imagem 1 %32 NABI XD Battery Replacement, Battery: passo 3, imagem 2 %32
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Battery Replacement: passo 4, imagem 1 %32
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
Conclusão
Equipe
USF Tampa, Team 17-2, Blackwell Fall 2016 Membro de USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
Membros da 3
Autoria de 12 guias
Um comentário
Where can you get the battery?
Dave - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 782
