Ir para o conteúdo principal
N64 Rumble Pak (Rumble WITHOUT batteries)
O que você precisa
  1. N64 Rumble Pak (Rumble WITHOUT batteries), Disassembly: passo 1, imagem 1 %32
    • Remove the 2 3.8mm gamebit screws
    • Disassemble the rumble pak and set the plastic housing aside.
  2. N64 Rumble Pak (Rumble WITHOUT batteries), Desolder/Resolder OEM resistor: passo 2, imagem 1 %32
    • Desolder the resistor just above the battery location on the pcb
    • Mine has already been modified. Original placement is highlighted.
    • Resolder the same resistor to the following through hole locations and solder into place. Conveniently, the resistor leads are long enough to reach these points and not require any extra wires.
    • Initially I applied solder to 1 through hole and attempted to push the lead through it after reheating with my iron. This proved quite the complication as I couldn't fully remelt the solder to get the lead through. Fearing overheating the resistor I managed to solder the lead in place without going through the pcb. This still works but I advise not
    • applying solder first.
  3. N64 Rumble Pak (Rumble WITHOUT batteries), Clean up/Reassembly: passo 3, imagem 1 %32 N64 Rumble Pak (Rumble WITHOUT batteries), Clean up/Reassembly: passo 3, imagem 2 %32
    • Clean up any flux you might have used and since the board is out you might as well give it a good clean with a electronic cleaner or high content isopropyl alcohol.
    • Reassemble the rumble pak and screw in the gamebit screws.
    • Having the battery compartment void of batteries causes you to hear the rattling of the battery terminals. I've invested in a set of 2 AAA dummy batteries to fill the compartment which will eliminate the sound by applying pressure to the once used battery springs. Anything can be used here really but I went for the exact fit in this case. The
    • rumble pak is relatively light without batteries and the dummy battery will help add some of it's original weight back.
Conclusão
Enjoy the battery free rumble of your N64 Rumble Pak. Thanks for reading and game on!
Navy Vet 2015
Membro desde: 06/25/15
7.460 Reputação
Autoria de 15 guias
Um comentário
Tried this and couldn't get the resistor out of the hole. i couldn't quite understand the warning in step 2 either
knoxium - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 37
Últimos 30 dias: 199
Duração total: 6,614
