Introdução
Batteries power the laser. If the laser is not working, one of the reasons might be the batteries. Follow the steps in this guide to correctly replace the batteries.
O que você precisa
The batteries are located in the handle of the blaster.
The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
Quase terminado!
Conclusão
