Ir para o conteúdo principal
MusicAngel JH-MD04E2 wired speakers Disassembly
O que você precisa
  1. MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: passo 1, imagem 1 %32 MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: passo 1, imagem 2 %32 MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: passo 1, imagem 3 %32
    • Bottom side has 4 5.95mm tapping Phillips #1 screws, under a rubber cover.
    • Under the label, there are two more Phillips #1 screws 9.15mm tapping screws.
  2. MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: passo 2, imagem 1 %32 MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: passo 2, imagem 2 %32 MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: passo 2, imagem 3 %32
    • Use a very thin metal prying tool and slide it in between the metal looking grill and the speaker body. Carefully pry it out (no glue is used) all the way around.
    • Repeat on both speaker sides.
  3. MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: passo 3, imagem 1 %32 MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: passo 3, imagem 2 %32 MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: passo 3, imagem 3 %32
    • Use a spudger to pry the battery that is glued to the top, from the body. Note: This is pretty strong adhesive.
    • Tilt the speaker grill / element a little, to slide it through the body.
  4. MusicAngel JH-MD04E2 wired speakers Disassembly, Information: passo 4, imagem 1 %32 MusicAngel JH-MD04E2 wired speakers Disassembly, Information: passo 4, imagem 2 %32 MusicAngel JH-MD04E2 wired speakers Disassembly, Information: passo 4, imagem 3 %32
    • As you can see, there are no connectors used. All connections are soldered directly to the board.
    • No information can be found on the battery, either side.
    • The speaker elements are 45mm, 3W and 4Ω
  5. MusicAngel JH-MD04E2 wired speakers Disassembly, Board overview: passo 5, imagem 1 %32
    • Not really much going on on this board.
Conclusão
Geir Ove Andersen
Membro desde: 06/06/22
7.752 Reputação
Autoria de 5 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.489 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 195
