Ir para o conteúdo principal
Munchkin Mozart Magic Cube Face plate Replacement
O que você precisa
  1. Munchkin Mozart Magic Cube Face plate  Replacement, Face plate: passo 1, imagem 1 %32 Munchkin Mozart Magic Cube Face plate  Replacement, Face plate: passo 1, imagem 2 %32
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Face plate  Replacement: passo 2, imagem 1 %32
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Face plate  Replacement: passo 3, imagem 1 %32
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Face plate  Replacement: passo 4, imagem 1 %32
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Face plate  Replacement: passo 5, imagem 1 %32
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Face plate  Replacement: passo 6, imagem 1 %32
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Face plate  Replacement: passo 7, imagem 1 %32
    • Remove the rubber corners by simply pulling them off.
Conclusão
Uma outra pessoa concluiu este guia.
Ibrahim Aldairem
Membro desde: 09/01/15
335 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-4, Sullivan Fall 2015 Membro de USF Tampa, Team 1-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G4
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 1,187
