Introdução
Leaks can occur within the Mr. Coffee TF6. In most cases, replacing the internal water tubes will correct this issue. You will require 2 inches of silicone tubing (.5 in. OD) to replace the original water tubes inside the TF6.
O que você precisa
Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the metal tubing on the TF6.
Uma outra pessoa concluiu este guia.
