Ir para o conteúdo principal
Mr. Coffee TF6 Dust Cover Replacement
O que você precisa
  1. Mr. Coffee TF6 Dust Cover Replacement, Dust Cover: passo 1, imagem 1 %32 Mr. Coffee TF6 Dust Cover Replacement, Dust Cover: passo 1, imagem 2 %32
    • Facing the front of the TF6, gently lift the dust cover along its hinge until it reaches its designed stopping point.
  2. Mr. Coffee TF6 Dust Cover Replacement: passo 2, imagem 1 %32 Mr. Coffee TF6 Dust Cover Replacement: passo 2, imagem 2 %32
    • Orient the retaining bracket upwards (away from the main body of unit).
    • Do not push the retaining bracket beyond its designed range of motion. It may snap if too much force is applied outside its limit.
  3. Mr. Coffee TF6 Dust Cover Replacement: passo 3, imagem 1 %32
    • With the retaining clip in its released position, pull the spout down towards the filter basket.
  4. Mr. Coffee TF6 Dust Cover Replacement: passo 4, imagem 1 %32 Mr. Coffee TF6 Dust Cover Replacement: passo 4, imagem 2 %32
    • Carefully detach the dust cover by disengaging the locking pins, starting at one side.
    • Extra force may be required to disengage the dust cover's locking pins. Refrain from applying excessive upward force on the dust cover, as dong so may cause the pins to snap under pressure.
Conclusão
Follow these steps in reverse order with a new Dust Cover.
Jordan
Membro desde: 01/31/14
204 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-18, Regan Winter 2014 Membro de Cal Poly, Team 13-18, Regan Winter 2014
CPSU-REGAN-W14S13G18
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 381
