Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Before replacing the heating plate, make sure that your machine is unplugged and dry, and that your work space is clean.
Peças
Nenhum componente especificado.
  1. Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean. Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver. Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Gently lift the base cover to expose the inside of the coffee machine.
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Kit de pontas universal para chave
    112 bits for every fix.
    Upgrade Your Toolbox
  5. Using the Phillips Head #2 screwdriver, remove the two 13 mm screws that secure the silver support bracket. Using the Phillips Head #2 screwdriver, remove the two 13 mm screws that secure the silver support bracket.
    • Using the Phillips Head #2 screwdriver, remove the two 13 mm screws that secure the silver support bracket.
  6. Gently lift the silver support bracket to free the heating plate from the heating coil.
    • Gently lift the silver support bracket to free the heating plate from the heating coil.
  7. Pinch and loosen the crimps with the needle-nose pliers. Pinch and loosen the crimps with the needle-nose pliers.
    • Pinch and loosen the crimps with the needle-nose pliers.
  8. Once the crimps are loosened, slide them down the tubing.
    • Once the crimps are loosened, slide them down the tubing.
  9. Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other. Gently pull them apart. Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other. Gently pull them apart.
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other. Gently pull them apart.
  10. Place your hand on the front side of the heating plate and push towards the bottom of the coffee maker to pop the heating plate out of place. Place your hand on the front side of the heating plate and push towards the bottom of the coffee maker to pop the heating plate out of place.
    • Place your hand on the front side of the heating plate and push towards the bottom of the coffee maker to pop the heating plate out of place.
Conclusão
6 outras pessoas concluíram este guia.
Luke Kraemer
Membro desde: 21-01-2014
230 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-31, Maness Winter 2014 Membro de Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Membros
6 Guias de autoria
so where do you get a replacement heating element (Im looking for one for a FTX49)
John Baker - Responder
You're missing steps and including unnecessary steps in this instruction. As well, you don't give a source for replacement warming plates. You might want to consider a rewrite.
chase canadé - Responder
I made a substitute hot plate from some sheet metal that I bought at the hardware store, and now I’m back in action with my delicious coffee.
Why they manufacture these plates out of poorly protected mild steel is beyond me. No, actually it isn’t beyond me - using inexpensive, unsuitable components certainly increases their profits. These plates almost certainly cost them less than 1¢ each, which is far cheaper than the 2¢ they’d pay for a suitable, durable part.
Lance J -
Before removing anything, do an in circuit resistance of those two small copper colored cylinders with a black end.
They are thermal fuses, and should have in circuit resistances close to zero.
Their placement is important, especially the one under the silver support bracket.
gdrgry34fsdf324 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 47
Duração total: 5,123
