Ir para o conteúdo principal
Mr. Coffee DRX5 Warming Plate Replacement
O que você precisa
  1. Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: passo 1, imagem 1 %32 Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: passo 1, imagem 2 %32 Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: passo 1, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
  2. Mr. Coffee DRX5 Warming Plate Replacement: passo 2, imagem 1 %32
    • Slide display out of the way.
  3. Mr. Coffee DRX5 Warming Plate Replacement: passo 3, imagem 1 %32 Mr. Coffee DRX5 Warming Plate Replacement: passo 3, imagem 2 %32 Mr. Coffee DRX5 Warming Plate Replacement: passo 3, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
  4. Mr. Coffee DRX5 Warming Plate Replacement: passo 4, imagem 1 %32
    • Pull heating element out of the way.
  5. Mr. Coffee DRX5 Warming Plate Replacement: passo 5, imagem 1 %32
    • Twist warming plate clockwise so that the tab is out of place. Remove warming plate.
Conclusão
Michael Chhim
Membro desde: 03/21/17
205 Reputação
Autoria de 2 guias
Equipe
Um comentário
Interesting that you can take the thing apart, do nothing else but put it back together again, and it’s supposed to be fixed? What about the step of replacing the broken part? I don’t see mention of that.
destravlr - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 15
Duração total: 601
