Ir para o conteúdo principal
Mpow 059 Ear Cushion Replacement
O que você precisa
  1. Mpow 059 Ear Cushion Replacement, Ear Cushion: passo 1, imagem 1 %32 Mpow 059 Ear Cushion Replacement, Ear Cushion: passo 1, imagem 2 %32
    • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
    • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
    • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
    • Applying too much pressure can damage ear cushion.
  2. Mpow 059 Ear Cushion Replacement: passo 2, imagem 1 %32
    • Remove the ear cushion away from the speaker to completely detach it from the headphones.
Conclusão
7 outras pessoas executaram este guia.
Danielle Furtado
Membro desde: 03/25/22
490 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team E-1, Gurgel Spring 2022 Membro de UMass Dartmouth, Team E-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SEG1
Membros da 3
Autoria de 4 guias
8 comentários
thank you. very helpfule.
P Gill - Responder
These instructions do not mention anything about the fact that you need a new adhesive to make the new earpads stay. Now I won't have headphones until I'm able to purchase an adhesive.
Cody Owens - Responder
Is there a recommendation on the replacement ear pads?
Some say glue is needed but does this depend on the replacement pads?
ms13sp - Responder
Works great. I have replaced my earpads 3 times with no glue. I use these MOKOS earpads from amazon. Replacement earpads for Mpow 059
Thanks for the step by step guide. I love these Mpow headphones, mostly for the controls on the right ear.
anotherdee - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 40
Últimos 30 dias: 159
Duração total: 6,095
