Ir para o conteúdo principal
Mountain Bike Brake Lever Replacement
O que você precisa
  1. Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: passo 1, imagem 1 %32 Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: passo 1, imagem 2 %32
    • Remove the grip from the handle.
    • Do this by twisting and pulling the grip until it slides off.
  2. Mountain Bike Brake Lever Replacement: passo 2, imagem 1 %32 Mountain Bike Brake Lever Replacement: passo 2, imagem 2 %32
    • Using a 5mm allen key, loosen the lever assembly from the handle.
    • Slide the assembly off of the handle.
  3. Mountain Bike Brake Lever Replacement: passo 3, imagem 1 %32
    • Take your new lever assembly and slide it onto the handle; leave it loose.
  4. Mountain Bike Brake Lever Replacement: passo 4, imagem 1 %32 Mountain Bike Brake Lever Replacement: passo 4, imagem 2 %32
    • Pour a light amount of isopropyl alcohol through your grip and slide it back onto the handle.
  5. Mountain Bike Brake Lever Replacement: passo 5, imagem 1 %32
    • Line up your lever assembly back into place.
    • Tighten the screw with the allen key to secure it.
  6. Mountain Bike Brake Lever Replacement: passo 6, imagem 1 %32 Mountain Bike Brake Lever Replacement: passo 6, imagem 2 %32 Mountain Bike Brake Lever Replacement: passo 6, imagem 3 %32
    • Install the brake cable into the lever housing.
    • Take the brake cable and feed it into the lever pull.
  7. Mountain Bike Brake Lever Replacement: passo 7, imagem 1 %32 Mountain Bike Brake Lever Replacement: passo 7, imagem 2 %32 Mountain Bike Brake Lever Replacement: passo 7, imagem 3 %32
    • Feed the cable into the lever assembly slot and through the barrel adjuster.
    • Use the barrel adjuster to tighten the cable intro place.
Conclusão
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 27
Últimos 30 dias: 120
Duração total: 3,664
