Ir para o conteúdo principal
Motorola syn1654A Speaker Module Replacement
O que você precisa
  1. Motorola syn1654A Speaker Module Replacement, Speaker Module: passo 1, imagem 1 %32 Motorola syn1654A Speaker Module Replacement, Speaker Module: passo 1, imagem 2 %32
    • See the speaker replacement guide and follow steps 1 and 2.
  2. Motorola syn1654A Speaker Module Replacement: passo 2, imagem 1 %32
    • Use the T6 torx screwdriver to remove the seven screws located around the headphone cover and place the screws in a safe place.
    • To avoid stripping screws, be sure to use the right drill bit oriented perpendicular to the face of the screw.
  3. Motorola syn1654A Speaker Module Replacement: passo 3, imagem 1 %32
    • Carefully lift the speaker out of its housing while leaving all wires connected.
  4. Motorola syn1654A Speaker Module Replacement: passo 4, imagem 1 %32
    • Lift the module out of the headphone cup, leaving all wires attached.
    • Clip the two wires circled in orange.
    • Now that the speaker is free set it aside.
    • Clip the two wires circled in yellow.
    • Replace speaker module and solder it to the two wires circled in orange.
    • Now solder the speaker wires (circled in yellow) back to the module.
    • For soldering see the ifixit soldering guide: Como soldar e dessoldar contatos
Conclusão
Ben
Membro desde: 02/24/14
104 Reputação
Autoria de 1 guia
Equipe
Michigan Tech, Team 5-1, Lauer Spring 2014 Membro de Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
Membros da 2
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 240
