Ir para o conteúdo principal
Motorola syn1654A Headphone Speaker Replacement
O que você precisa
  1. Motorola syn1654A Headphone Speaker Replacement, Headphone Speaker: passo 1, imagem 1 %32
    • Make sure the headphones are off and unplugged from any devices.
    • Remove leather headphone cushion by pulling edge towards middle of headphone.
    • It should slip off the device.
  2. Motorola syn1654A Headphone Speaker Replacement: passo 2, imagem 1 %32
    • Carefully peel back foam pad to prevent tearing.
    • It is glued at both the top and bottom.
  3. Motorola syn1654A Headphone Speaker Replacement: passo 3, imagem 1 %32
    • Use the T6 torx screwdriver to remove the three screws holding the speaker in place.
    • To avoid stripping screws, be sure to use the right screw bit oriented perpendicular to the face of the screw.
  4. Motorola syn1654A Headphone Speaker Replacement: passo 4, imagem 1 %32
    • With the speaker removed from the speaker module, clip the black and white wires on the back of the speaker, as shown.
    • Solder wires onto corresponding pads of replacement speaker.
    • For soldering see the ifixit soldering guide: Como soldar e dessoldar contatos
Conclusão
John Ware
Membro desde: 02/24/14
325 Reputação
Autoria de 2 guias
Equipe
Michigan Tech, Team 5-1, Lauer Spring 2014 Membro de Michigan Tech, Team 5-1, Lauer Spring 2014
MTU-LAUER-S14S5G1
Membros da 2
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 389
