Ir para o conteúdo principal
Motorola i90c Midframe Replacement
O que você precisa
  1. Motorola i90c Midframe Replacement, Battery: passo 1, imagem 1 %32 Motorola i90c Midframe Replacement, Battery: passo 1, imagem 2 %32 Motorola i90c Midframe Replacement, Battery: passo 1, imagem 3 %32
    • Slide the notch downward while pulling the back cover off to remove it.
    Pergunte ao FixBot
    Comentar
  2. Motorola i90c Midframe Replacement: passo 2, imagem 1 %32 Motorola i90c Midframe Replacement: passo 2, imagem 2 %32 Motorola i90c Midframe Replacement: passo 2, imagem 3 %32
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
    Pergunte ao FixBot
    Comentar
  3. Motorola i90c Midframe Replacement, Antenna: passo 3, imagem 1 %32 Motorola i90c Midframe Replacement, Antenna: passo 3, imagem 2 %32
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
    Pergunte ao FixBot
    Comentar
  4. Motorola i90c Midframe Replacement, Midframe: passo 4, imagem 1 %32 Motorola i90c Midframe Replacement, Midframe: passo 4, imagem 2 %32 Motorola i90c Midframe Replacement, Midframe: passo 4, imagem 3 %32
    • Unscrew the 3 screws shown.
    • Lift the right part of the Nextel logo
    • Remove the screw underneath.
    Pergunte ao FixBot
    Comentar
  5. Motorola i90c Midframe Replacement: passo 5, imagem 1 %32 Motorola i90c Midframe Replacement: passo 5, imagem 2 %32
    • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
    • Gently lift the back cover off.
    Pergunte ao FixBot
    Comentar
  6. Motorola i90c Midframe Replacement: passo 6, imagem 1 %32 Motorola i90c Midframe Replacement: passo 6, imagem 2 %32 Motorola i90c Midframe Replacement: passo 6, imagem 3 %32
    • Find the connection between the headphone jack and logic board.
    • Begin separating the two pieces, slowly and carefully.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Equipe
Cal Poly, Team 29-61, Johann Spring 2010 Membro de Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 40
Ao todo: 1,640
