Ir para o conteúdo principal
Motorola i850 LCD Screen Replacement
O que você precisa
  1. Motorola i850 LCD Screen Replacement, LCD Board: passo 1, imagem 1 %32
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Motorola i850 LCD Screen Replacement: passo 2, imagem 1 %32 Motorola i850 LCD Screen Replacement: passo 2, imagem 2 %32
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Motorola i850 LCD Screen Replacement: passo 3, imagem 1 %32
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Motorola i850 LCD Screen Replacement: passo 4, imagem 1 %32
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Motorola i850 LCD Screen Replacement: passo 5, imagem 1 %32
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Motorola i850 LCD Screen Replacement: passo 6, imagem 1 %32
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Motorola i850 LCD Screen Replacement: passo 7, imagem 1 %32
    • Completely remove the outer casing from the phone.
  8. Motorola i850 LCD Screen Replacement: passo 8, imagem 1 %32 Motorola i850 LCD Screen Replacement: passo 8, imagem 2 %32
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Motorola i850 LCD Screen Replacement: passo 9, imagem 1 %32
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Motorola i850 LCD Screen Replacement: passo 10, imagem 1 %32
    • Prop out the LCD board from the phone using your fingertips.
  11. Motorola i850 LCD Screen Replacement: passo 11, imagem 1 %32 Motorola i850 LCD Screen Replacement: passo 11, imagem 2 %32
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
  12. Motorola i850 LCD Screen Replacement, LCD Screen: passo 12, imagem 1 %32
    • Firmly detach the gold strip using a Tweezer.
  13. Motorola i850 LCD Screen Replacement: passo 13, imagem 1 %32
    • Prop out the LCD screen using a Small Flathead Screwdriver.
  14. Motorola i850 LCD Screen Replacement: passo 14, imagem 1 %32 Motorola i850 LCD Screen Replacement: passo 14, imagem 2 %32 Motorola i850 LCD Screen Replacement: passo 14, imagem 3 %32
    • Remove the LCD screen from the LCD board.
Conclusão
Andrew Aw
Membro desde: 04/08/10
1 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 34-56, Forte Spring 2010 Membro de Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 2,108
