Ir para o conteúdo principal
Motorola i710 Microphone Replacement
O que você precisa
  1. Motorola i710 Microphone Replacement, Battery Cover: passo 1, imagem 1 %32 Motorola i710 Microphone Replacement, Battery Cover: passo 1, imagem 2 %32
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    Pergunte ao FixBot
    Comentar
  2. Motorola i710 Microphone Replacement, Battery: passo 2, imagem 1 %32
    • Push the battery towards the top of the phone and lift up.
    Pergunte ao FixBot
    Comentar
  3. Motorola i710 Microphone Replacement, Back Casing: passo 3, imagem 1 %32 Motorola i710 Microphone Replacement, Back Casing: passo 3, imagem 2 %32 Motorola i710 Microphone Replacement, Back Casing: passo 3, imagem 3 %32
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
    Pergunte ao FixBot
    Comentar
  4. Motorola i710 Microphone Replacement, Microphone: passo 4, imagem 1 %32 Motorola i710 Microphone Replacement, Microphone: passo 4, imagem 2 %32 Motorola i710 Microphone Replacement, Microphone: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Lift the circuit board away from the case of the phone, being careful not to break the wire that goes up into the hinge. This will give you access to the microphone.
    • The microphone sits just below the keys on the front cover molding.
    • Grasp the microphone with tweezers and lift it out of the front cover.
    Pergunte ao FixBot
    Comentar
Conclusão
Carson Meena
Membro desde: 10/22/12
16 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 14-2, Benson Fall 2012 Membro de Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 54
Ao todo: 582
