Ir para o conteúdo principal
Motorola i710 LCD Screen Cover Replacement
O que você precisa
  1. Motorola i710 LCD Screen Cover Replacement, Battery Cover: passo 1, imagem 1 %32 Motorola i710 LCD Screen Cover Replacement, Battery Cover: passo 1, imagem 2 %32
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 LCD Screen Cover Replacement, Battery: passo 2, imagem 1 %32
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: passo 3, imagem 1 %32 Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: passo 3, imagem 2 %32 Motorola i710 LCD Screen Cover Replacement, LCD Screen Cover: passo 3, imagem 3 %32
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
  4. Motorola i710 LCD Screen Cover Replacement: passo 4, imagem 1 %32 Motorola i710 LCD Screen Cover Replacement: passo 4, imagem 2 %32
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
  5. Motorola i710 LCD Screen Cover Replacement: passo 5, imagem 1 %32 Motorola i710 LCD Screen Cover Replacement: passo 5, imagem 2 %32 Motorola i710 LCD Screen Cover Replacement: passo 5, imagem 3 %32
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
Conclusão
Carson Meena
Membro desde: 10/22/12
16 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 14-2, Benson Fall 2012 Membro de Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Membros
Autoria de 17 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 65
Ao todo: 660
