Introdução
The side volume button installation guide will require removal of the battery to access the location of the side volume button. This guide can be used to replace damaged volume buttons.
Peças
Não são necessárias peças.
  1. Place thumb on the rubber tab on the lower back of the phone.
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Lift the back panel of the phone to expose battery (not shown here).
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Pull antenna up, away from the phone, to reveal two of six screws.
    • Pull antenna up, away from the phone, to reveal two of six screws.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
    • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  6. Gently separate the front and back sides of the phone. Be careful not to break or bend the ribbon cables.
    • Gently separate the front and back sides of the phone.
    • Be careful not to break or bend the ribbon cables.
  7. Detach the first ribbon cable by unplugging it from the logic board. Detach the first ribbon cable by unplugging it from the logic board.
    • Detach the first ribbon cable by unplugging it from the logic board.
  8. Gently remove the side button by pulling the buttons away from the phone. Gently remove the side button by pulling the buttons away from the phone. Gently remove the side button by pulling the buttons away from the phone.
    • Gently remove the side button by pulling the buttons away from the phone.
Conclusão
Haley S
10 reputação
4 Guides authored
Equipe
Clemson, Team 13-6, Benson Spring 2013 Membro de Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Membros
10 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 113
