Ir para o conteúdo principal
Motorola i560 Microphone Replacement
O que você precisa
  1. Motorola i560 Microphone Replacement, Battery: passo 1, imagem 1 %32
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Microphone Replacement: passo 2, imagem 1 %32
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Microphone Replacement, Side Volume Button: passo 3, imagem 1 %32
    • Pull antenna up, away from the phone, to reveal two of six screws.
  4. Motorola i560 Microphone Replacement: passo 4, imagem 1 %32
    • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  5. Motorola i560 Microphone Replacement: passo 5, imagem 1 %32 Motorola i560 Microphone Replacement: passo 5, imagem 2 %32
    • Gently separate the front and back sides of the phone.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Microphone Replacement: passo 6, imagem 1 %32 Motorola i560 Microphone Replacement: passo 6, imagem 2 %32
    • Detach the first ribbon cable by unplugging it from the logic board.
  7. Motorola i560 Microphone Replacement: passo 7, imagem 1 %32 Motorola i560 Microphone Replacement: passo 7, imagem 2 %32 Motorola i560 Microphone Replacement: passo 7, imagem 3 %32
    • Gently remove the side button by pulling the buttons away from the phone.
  8. Motorola i560 Microphone Replacement, Metal Support Plate: passo 8, imagem 1 %32 Motorola i560 Microphone Replacement, Metal Support Plate: passo 8, imagem 2 %32 Motorola i560 Microphone Replacement, Metal Support Plate: passo 8, imagem 3 %32
    • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
  9. Motorola i560 Microphone Replacement, Microphone: passo 9, imagem 1 %32 Motorola i560 Microphone Replacement, Microphone: passo 9, imagem 2 %32 Motorola i560 Microphone Replacement, Microphone: passo 9, imagem 3 %32
    • Slightly bend the phone frame to expose microphone protrusion.
    • Gently remove microphone using your fingers.
  10. Motorola i560 Microphone Replacement: passo 10, imagem 1 %32
    • Once the microphone has been removed, remove the connecting piece
Conclusão
Haley S
Membro desde: 03/11/13
10 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 13-6, Benson Spring 2013 Membro de Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 11
Duração total: 159
