Ir para o conteúdo principal
Motorola i560 Keypad Replacement
O que você precisa
  1. Motorola i560 Keypad Replacement, Battery: passo 1, imagem 1 %32
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Keypad Replacement: passo 2, imagem 1 %32
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Keypad Replacement, Motherboard: passo 3, imagem 1 %32
    • Pull the antenna up to reveal two of the six screws.
  4. Motorola i560 Keypad Replacement: passo 4, imagem 1 %32
    • Unscrew all six screws on the back side of the phone using a T-6 bit.
  5. Motorola i560 Keypad Replacement: passo 5, imagem 1 %32 Motorola i560 Keypad Replacement: passo 5, imagem 2 %32
    • Gently separate the front and back sides of the phone, as shown in the picture.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Keypad Replacement: passo 6, imagem 1 %32 Motorola i560 Keypad Replacement: passo 6, imagem 2 %32
    • Detach the first ribbon cable by unplugging it from the motherboard.
  7. Motorola i560 Keypad Replacement: passo 7, imagem 1 %32 Motorola i560 Keypad Replacement: passo 7, imagem 2 %32
    • Detach the speaker ribbon cable from the motherboard.
  8. Motorola i560 Keypad Replacement: passo 8, imagem 1 %32
    • Remove the motherboard from the front half of the phone by gently shaking it loose. It should come out with little to no trouble.
  9. Motorola i560 Keypad Replacement, Keypad: passo 9, imagem 1 %32
    • Push lightly from the front of the keypad to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Haley S
Membro desde: 03/11/13
10 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 13-6, Benson Spring 2013 Membro de Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 159
