Introdução
The headphone port allows the user to redirect the speaker output to a pair of headphones when the headphones are plugged into the port.
O que você precisa
Place the phone on a flat surface with the front facing down.
Insert your finger under the gray plastic cover at the bottom end of the phone.
Lift the cover off the phone.
Place your thumb in the notch in the lower left corner of the battery compartment.
Lift the battery up and away from the phone.
Remove the battery.
Locate the metal slider that holds the SIM card in place.
Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
Locate the headphone port at the bottom right corner of the circuit board.
