Ir para o conteúdo principal
Motorola i450 Boost Mobile Headphone Port Replacement
O que você precisa
  1. Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: passo 1, imagem 1 %32 Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: passo 1, imagem 2 %32 Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: passo 1, imagem 3 %32
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile Headphone Port Replacement, Battery: passo 2, imagem 1 %32 Motorola i450 Boost Mobile Headphone Port Replacement, Battery: passo 2, imagem 2 %32 Motorola i450 Boost Mobile Headphone Port Replacement, Battery: passo 2, imagem 3 %32
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile Headphone Port Replacement, SIM Card: passo 3, imagem 1 %32 Motorola i450 Boost Mobile Headphone Port Replacement, SIM Card: passo 3, imagem 2 %32
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile Headphone Port Replacement: passo 4, imagem 1 %32 Motorola i450 Boost Mobile Headphone Port Replacement: passo 4, imagem 2 %32 Motorola i450 Boost Mobile Headphone Port Replacement: passo 4, imagem 3 %32
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Motorola i450 Boost Mobile Headphone Port Replacement, Circuit Board: passo 5, imagem 1 %32
    • Extend the antenna.
  6. Motorola i450 Boost Mobile Headphone Port Replacement: passo 6, imagem 1 %32
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Motorola i450 Boost Mobile Headphone Port Replacement: passo 7, imagem 1 %32 Motorola i450 Boost Mobile Headphone Port Replacement: passo 7, imagem 2 %32 Motorola i450 Boost Mobile Headphone Port Replacement: passo 7, imagem 3 %32
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  8. Motorola i450 Boost Mobile Headphone Port Replacement, Headphone Port: passo 8, imagem 1 %32
    • Locate the headphone port at the bottom right corner of the circuit board.
    • The headphone port cannot be removed from the phone. If cleaning the port does not fix the problem, the entire phone must be replaced.
Conclusão
Garrison Stevens
Membro desde: 10/22/12
1 Reputação
Autoria de 6 guias
Equipe
Clemson, Team 15-2, Benson Fall 2012 Membro de Clemson, Team 15-2, Benson Fall 2012
CLEM-BENSON-F12S15G2
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 13
Duração total: 395
