Introdução
The antenna greatly affects the quality of the phone's reception.
O que você precisa
Place the phone on a flat surface with the front facing down and the antenna fully extended.
Use a spudger to remove the circular rubber cover from the base of the antenna.
Remove the 3.2 mm Torx T5 screw located under the rubber cover.
Quase terminado!
Conclusão
