Ir para o conteúdo principal
Motorola i1000plus Back Cover Replacement
O que você precisa
  1. Motorola i1000plus Back Cover Replacement, Battery: passo 1, imagem 1 %32 Motorola i1000plus Back Cover Replacement, Battery: passo 1, imagem 2 %32 Motorola i1000plus Back Cover Replacement, Battery: passo 1, imagem 3 %32
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Back Cover Replacement, Antenna: passo 2, imagem 1 %32 Motorola i1000plus Back Cover Replacement, Antenna: passo 2, imagem 2 %32 Motorola i1000plus Back Cover Replacement, Antenna: passo 2, imagem 3 %32
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Back Cover Replacement, Back Cover: passo 3, imagem 1 %32 Motorola i1000plus Back Cover Replacement, Back Cover: passo 3, imagem 2 %32 Motorola i1000plus Back Cover Replacement, Back Cover: passo 3, imagem 3 %32
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Back Cover Replacement: passo 4, imagem 1 %32
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Back Cover Replacement: passo 5, imagem 1 %32
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Back Cover Replacement: passo 6, imagem 1 %32 Motorola i1000plus Back Cover Replacement: passo 6, imagem 2 %32 Motorola i1000plus Back Cover Replacement: passo 6, imagem 3 %32
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
Conclusão
Austin Lake
Membro desde: 10/18/13
501 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 13-3, Benson Fall 2013 Membro de Clemson, Team 13-3, Benson Fall 2013
CLEM-BENSON-F13S13G3
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 210
