Introdução
Over time, the covers on cell phones can become worn or even broken. This guide will show users how to replace the back cover on this device. This guide does not require much technical knowledge. The user should know how to use a screwdriver to remove two screws and a spudger to pry pieces off of the phone.
O que você precisa
Push the tab located at the bottom of the battery towards the top of the phone.
Lift the battery away from the phone.
Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
Pull the antenna straight out of the phone.
