Ir para o conteúdo principal
Motorola Xoom Wifi Earphone Port Replacement
O que você precisa
  1. Motorola Xoom Wifi Earphone Port Replacement, Back Cover Disassembly: passo 1, imagem 1 %32 Motorola Xoom Wifi Earphone Port Replacement, Back Cover Disassembly: passo 1, imagem 2 %32
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Earphone Port Replacement: passo 2, imagem 1 %32 Motorola Xoom Wifi Earphone Port Replacement: passo 2, imagem 2 %32
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Earphone Port Replacement: passo 3, imagem 1 %32 Motorola Xoom Wifi Earphone Port Replacement: passo 3, imagem 2 %32 Motorola Xoom Wifi Earphone Port Replacement: passo 3, imagem 3 %32
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: passo 4, imagem 1 %32 Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: passo 4, imagem 2 %32 Motorola Xoom Wifi Earphone Port Replacement, Earphone Port: passo 4, imagem 3 %32
    • Remove one screw with a T-5 bit.
    • Lift the black casing off of the ports.
    • Remove earphone port from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
William Prins
Membro desde: 04/14/14
583 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-39, Maness Spring 2014 Membro de Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 250
