Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
As this replacement guide works on an internal component of the Xoom Wifi, completion of prior steps to remove external parts is necessary.
O que você precisa
There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
Apply light pressure with hand and slide the back plate till it stops in this position.
There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
As soon as the clips are released the back should slide off.
Remove the two battery leads with a T-5 Torx screwdriver.
Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
Replace speaker if necessary.
Use a spudger or a fine tip to lift the black tab to a vertical position.
A spudger is needed to remove the plastic border around the camera.
Take a plastic opening tool and carefully pry off the touch screen controller connection.
Be careful with the black cover under the connection.
There are eight 3.5mm screws that hold the motherboard in. Use a T-5 Torx screwdriver to take the screws loose. These screws are outlined in a gold color on the motherboard.
Two gold colored screws with brackets are located in the orange circles. A T-5 Torx screwdriver is needed to take these 3.1mm screws.
Motherboard should lift out easily and completely.
Using the T-6 Torx screwdriver, unscrew the 17 4mm screws along the edge of the screen frame.
5 outras pessoas executaram este guia.
