Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
As this replacement guide works on an external component of the Xoom Wifi, there are no prerequisite steps.
O que você precisa
There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
Apply light pressure with hand and slide the back plate till it stops in this position.
There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
As soon as the clips are released the back should slide off.
4 outras pessoas executaram este guia.
