Ir para o conteúdo principal
Motorola Xoom Wifi Back Cover Disassembly
O que você precisa
  1. Motorola Xoom Wifi Back Cover Disassembly, Back Cover Disassembly: passo 1, imagem 1 %32 Motorola Xoom Wifi Back Cover Disassembly, Back Cover Disassembly: passo 1, imagem 2 %32
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Back Cover Disassembly: passo 2, imagem 1 %32 Motorola Xoom Wifi Back Cover Disassembly: passo 2, imagem 2 %32
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Back Cover Disassembly: passo 3, imagem 1 %32 Motorola Xoom Wifi Back Cover Disassembly: passo 3, imagem 2 %32 Motorola Xoom Wifi Back Cover Disassembly: passo 3, imagem 3 %32
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
Conclusão
4 outras pessoas executaram este guia.
Mallika
Membro desde: 04/20/14
464 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-39, Maness Spring 2014 Membro de Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,299
