Ir para o conteúdo principal
Motorola XOOM 2 Media Edition Battery Replacement
O que você precisa
  1. Motorola XOOM 2 Media Edition Battery Replacement, Battery: passo 1, imagem 1 %32 Motorola XOOM 2 Media Edition Battery Replacement, Battery: passo 1, imagem 2 %32
    • Power off your tablet before beginning disassembly.
    • Remove six 2.74mm Torx #3 screws from the back panel of the device with a Torx T3 screwdriver.
  2. Motorola XOOM 2 Media Edition Battery Replacement: passo 2, imagem 1 %32 Motorola XOOM 2 Media Edition Battery Replacement: passo 2, imagem 2 %32
    • There is adhesive attached to the underside of the back panel. Gradually lift panel to avoid bending it out of shape.
    • Pry off the back panel with a plastic opening tool.
  3. Motorola XOOM 2 Media Edition Battery Replacement: passo 3, imagem 1 %32 Motorola XOOM 2 Media Edition Battery Replacement: passo 3, imagem 2 %32
    • These screws are tight and prone to becoming stripped.
    • The battery cables are likely to snap when removing the screws.
    • Remove two 2.38mm Torx #5 screws from battery cables with Torx T5 screwdriver.
  4. Motorola XOOM 2 Media Edition Battery Replacement: passo 4, imagem 1 %32 Motorola XOOM 2 Media Edition Battery Replacement: passo 4, imagem 2 %32 Motorola XOOM 2 Media Edition Battery Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull up the battery cables and battery chip with tweezers.
  5. Motorola XOOM 2 Media Edition Battery Replacement: passo 5, imagem 1 %32 Motorola XOOM 2 Media Edition Battery Replacement: passo 5, imagem 2 %32
    • Pry the battery out of the device with the plastic opening tool.
    • Some force is needed to lift the battery up because of the adhesive attached to the backside of the battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,077
