Ir para o conteúdo principal
Motorola W490 SIM Card Replacement
O que você precisa
  1. Motorola W490 SIM Card Replacement, Phone Casing: passo 1, imagem 1 %32 Motorola W490 SIM Card Replacement, Phone Casing: passo 1, imagem 2 %32
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
    Pergunte ao FixBot
    Comentar
  2. Motorola W490 SIM Card Replacement, Battery: passo 2, imagem 1 %32 Motorola W490 SIM Card Replacement, Battery: passo 2, imagem 2 %32
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
    Pergunte ao FixBot
    Comentar
  3. Motorola W490 SIM Card Replacement, SIM Card: passo 3, imagem 1 %32 Motorola W490 SIM Card Replacement, SIM Card: passo 3, imagem 2 %32 Motorola W490 SIM Card Replacement, SIM Card: passo 3, imagem 3 %32
    • Use a plastic opening tool to make a gap between the SIM card and the phone.
    • Use your thumb and index finger to pull the SIM card from the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Will Edwards
Membro desde: 10/22/12
61 Reputação
Autoria de 9 guias
Equipe
Clemson, Team 14-1, Benson Fall 2012 Membro de Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Membros
Autoria de 23 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 48
Ao todo: 1,141
